Property Description | Property Label |
New Item Manufacturer | c2m_newitem_manufacturer |
Existing Item Manufacturer | c2m_item_manufacturer |
New Meter Manufacturer | c2m_newmeter_manufacturer |
Existing Meter Manufacturer | c2m_meter1_mfg |
New Meter Model | c2m_newmeter_model |
Existing Meter Model | c2m_meter1_model |
New Item Model | c2m_newitem_model |
Existing Item Model | c2m_item_model |
New Meter Configuration Type | c2m_new_meter_type |
Existing Meter Configuration Type | c2m_meter1_type |
New Item Configuration Type | c2m_new_item_type |
Existing Item Configuration Type | c2m_item_type |
New Meter Device Type | c2m_newmeter_devicetype |
Existing Meter Device Type | c2m_deviceType |
New Item Device Type | c2m_newitem_deviceType |
Existing Item Device Type | c2m_item_device_type |
New Meter Head End System | c2m_newmeter_headend |
Existing Meter Head End System | c2m_headendSystem |
Property Name | Default Value | Comments |
som.adminsync.configurationtype.properties.count | 4 | Change the value if you want to add new property for configuration type |
som.adminsync.manufacturer.properties.count | 4 | Change the value if you want to add new property for manufacturer |
som.adminsync.model.properties.count | 4 | Change the value if you want to add new property for model |
som.adminsync.devicetypes.properties.count | 4 | Change the value if you want to add new property for device types |
som.adminsync.headendsystem.properties.count | 2 | Change the value if you want to add new property for head end system |
