User Types
User types manage all user permissions. Each user type has a profile that defines security and display permissions, such as the user's login method, the ability to use certain functions, and access to menu items and properties. Screen-configuration settings define the screens, windows, pop-up windows and other elements visible to a certain user type. They also support the context layout editor, in which the content, arrangement, and visibilities of each context are set.
Use the Screen Configuration settings in specific user types to create custom screen context layouts for the integration.
Prerequisite! Make sure the Properties, Activity Types, and Plugins are loaded before proceeding.
To configure the user types:
1. Navigate to the Configuration page.
2. Click the User Types icon.
3. Click
Import to import the user types.
4. On the
Choose file field, click
Browse to select the user type. Click
Validate.
5. After successful validation, click
Import to import the file.
6. Verify the successful import and click
Close.
Configuring Time Format
The time format can be changed from 12 hour to 24 hour. Oracle Fields Service has the provision to configure in the user type file. The user type file is in 12 hour format by default.
To change the time format:
1. Login to Oracle Field Service.
2. Navigate to Configuration > User type > C2M OFSC.
3. Click
Screen Configuration and select
Preferences.
4. Click
Property, then click the value in the
Value visibility section.
5. Click Save.
