User Operations
This chapter provides step by step instructions for user operations.
1. Login to Oracle Field Service Mobility application.
You can access the application by adding '/m' to the Oracle Field Service URL <ofsc_link/m>.
2. Access the Mobility page using the worker/technician's credentials. The page shows activities in the queue of the worker.
3. Click
Start to start the activity in the worker's queue.
![Mobility page. Mobility page.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-1-mobility%20page.png)
4. Click “>” against the activity. The options
Start,
Cancel,
Suspend,
Map and
Book Activity are displayed.
![Activity Details page detail. The Start button is the first one at the top from left to right. Activity Details page detail. The Start button is the first one at the top from left to right.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-2-start.png)
5. Click Start to start the activity in the worker's queue.
6. Enter the odometer details and click
Submit.
![Start Activity page. The submit button is located on the bottom right corner. Start Activity page. The submit button is located on the bottom right corner.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-3-start-activity.png)
7. Click
Meter Details. Enter the
Badge Number and click
Submit.
![Meter information page with several text fields. The Submit button is located on the bottom right corner. Meter information page with several text fields. The Submit button is located on the bottom right corner.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-4-meter-details.png)
8. Click
Meter Details, then click
Verify. After the verification is successful, the meter reading information is displayed in the
Registers Information section.
![Device Details page. Device Details page.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-5-verify-meter-details.png)
![Meter information section on the left column, and Registers information section on the right column. Meter information section on the left column, and Registers information section on the right column.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-6-meter-info.png)
9. Enter the respective details in the Meter Information and Registers Information sections. Click Submit.
10. Click
Complete.
![Activity Details page showing the service information on the left column, and the service point details on the right. The Complete button is located at the top of the page and it is the first button from left to right. Activity Details page showing the service information on the left column, and the service point details on the right. The Complete button is located at the top of the page and it is the first button from left to right.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-7-activity-details.png)
11. On the
End Activity page, enter the required details. Click
Submit.![End Activity page. The submit button is located on the bottom right corner. End Activity page. The submit button is located on the bottom right corner.](../CCS-OFS-SETUP-GUIDE-22C/images/user-operations-7-submit-details.png)
