Creating a Backup
Take a backup of the following:
• Oracle Integration Cloud Prebuilt Integration: Export the Oracle Integration Cloud package and integration flows from Oracle Integration Cloud and store them in the local folder.
Note: Currently, Business Accelerator packages cannot be exported. If there are no changes to the base “outl.ba.ccs_ofsc_fieldwork.1_0_0” package, make sure to take a backup of the Oracle Integration Cloud lookups. If the base package is cloned and the customizations are included in the cloned flows or if an older version package existed before consuming Oracle Integration Cloud accelerator (oracle.util.somofsc.fieldwork.par), take a backup of the Oracle Integration Cloud package.
To export the package and integration flows:
a. Login to Oracle Integration Cloud.
b. Navigate to Packages from integrations.
c. Select the required package to be exported.
d. Browse to the path where the package has to be exported and click Export.
• Oracle Field Service Properties: Export the Oracle Field Service properties that start with “c2m_” and store/save them in the local folder.
• Oracle Field Service User Type: Export the user type file from the Oracle Field Service environment.
• Oracle Field Service Plugin: Export the Oracle Field Service plugin from Oracle Field Service environment.
For detailed steps to take a backup of the process, refer to the Oracle Utilities Customer Cloud Service Integration to Oracle Field Service Configuration Guide included in this release. The documentation is available on Oracle Help Center at:
