Table Name | drms_parameters |
OIC flow end point URL | • Update the value with OIC flow end point URL <https://hostname:port /ic/api/integration/v1/flows/oracleutilities/OUTL-BA-DRMS_DACS_DEV_STAT_ACK/1.0/status-check-ack-to-dacs where the attrib = 'OIC_STATUS_ACK_URL' • Update the value with OIC flow end point url <https://hostname:port/ ic/api/integration/v1/flows/rest/OUTL_BA_DRMS_DACS_EVT_DVCRESV/1.0/reserveDevice> where the attrib=' OIC_RESERVE_DEVICE_URL' • Update the value with OIC flow end point url <https://hostname:port /ic/api/integration/v1/flows/rest/OUTL_BA_DRMS_DACS_PRE_EVENT_CANC/1.0/preEventCancel where the attrib = 'OIC_EVENT_CANCEL_URL' • Update the value with OIC flow end point url <https://hostname:port ic/api/integration/v1/flows/oracleutilities/OUTL-BA-DRMS_DACS_ENROLLRQ/1.0/enroll-to-dacs where the attrib = 'OIC_ENROLL_URL' • Update the value with < OIC_USER Name> where the attrib=' OIC_USER' • Update the value with <oic password> where the attrib=' OIC_PASS ' |
