Known Issues
Following are the known issues that impact the integration flows with respect to the supported application versions:
• Status of the program subscription is being transitioned incorrectly to ACTIVE in Oracle Utilities Digital Asset Cloud Service on receipt of the enrollment request from the integration layer. It should be in the INACTIVE status until the enrollment process is completed. It could result in sending not fully enrolled customer details to Oracle Utilities Grid Edge Distributed Energy Resources Management System when the Enrollment Sync message is triggered.
• The unenrollment process in Oracle Utilities Digital Asset Cloud Service is not setting the correct values for program subscription status, program end date, and device status. Hence, the outbound message is not being sent to the integration layer. Oracle Utilities Grid Edge Distributed Energy Resources Management System will not be aware of unenrolled customers and continue to evaluate the associated devices during program event creation.
• Oracle Utilities Digital Asset Cloud Service is allowing duplicate device identifiers to be created during the enrollment process. This impacts the device score calculation as the device score file gets multiple records for the same device. Oracle Utilities Grid Edge Distributed Energy Resources Management System could get an incorrect device score value resulting in poor customer experience.
• Oracle Utilities Grid Edge Distributed Energy Resources Management System is returning a failure response for all device status check requests triggered from Oracle Utilities Digital Asset Cloud Service. This is happening as Oracle Utilities Grid Edge Distributed Energy Resources Management System does not have the functionality to retrieve the device status from Oracle Utilities Live Energy Connect during enrollment. The enrollment process will fail in Oracle Utilities Digital Asset Cloud Service for all devices that support this configuration.
