OCI Target Notification Stream | "Responsys //rest/api/v1.3/campaigns/{notifcationTemplate}/sms //rest/api/v1.3/campaigns/{notifcationTemplate}/email " | DVM | Comments | ||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | ||
messageId | Field | ||||||
origin | Field | ||||||
accountId | Field | optionalData/value (optionalData/key = INT_ACCOUNT_ID') | mergeTriggerRecordData/mergeTriggerRecords | ||||
notificationType | Field | optionalData/value (optionalData/key = INT_NOTIFTYPE') | mergeTriggerRecordData/mergeTriggerRecords | ||||
cisDivision | Field | mergeTriggerRecordData/mergeTriggerRecords | |||||
contactId | Field | optionalData/value (optionalData/key = INT_CONTACT_ID') | mergeTriggerRecordData/mergeTriggerRecords | ||||
personId | Field | optionalData/value (optionalData/key = INT_PERSON_ID') | mergeTriggerRecordData/mergeTriggerRecords | ||||
language | Field | mergeTriggerRecordData/mergeTriggerRecords | |||||
firstName | Field | optionalData/value (optionalData/key = INT_FIRST_NAME') | mergeTriggerRecordData/mergeTriggerRecords | ||||
lastName | Field | optionalData/value (optionalData/key = 'INT_LAST_NAME') | mergeTriggerRecordData/mergeTriggerRecords | ||||
deliveryChannel | Field | OUTL-BRT-NOTIFHUB_ DeliveryChannel | This lookup is used to determine if the SMS or Email campaign API needs to be invoked. | ||||
deliveryValue | Field | fieldValues | mergeTriggerRecordData/mergeTriggerRecords | ||||
notificationTemplate | Field | This value is used to populate the campaign name in the API URL. | |||||
deliveryInstance | Field | This value is used to determine the Responsys instance to invoke. RESP1,RESP2,RESP3 corresponding to three Responsys instance connections that is provided out of the box. | |||||
CCId | Field | optionalData/value (optionalData/key = 'INT_CC_ID') | |||||
notifPreferenceId | Field | optionalData/value (optionalData/key = 'INT_NOTIF_PREF_ID') | |||||
optOutAllowed | Field | optionalData/value (optionalData/key = 'INT_OPTOUT_ALLOWED') | |||||
custContactNeeded | Field | optionalData/value (optionalData/key = 'INT_CUST_CONTACT_NEEDED') | |||||
subscriptionType | Field | optionalData/value (optionalData/key = 'INT_SUB_TYPE') | |||||
notifEventInstanceId | Field | optionalData/value (optionalData/key = 'INT_NOTIF_EVNT_ID') | |||||
sourceMessageId | Field | optionalData/value (optionalData/key = 'INT_SOURCE_MSG_ID') | |||||
eventCapturedDTTM | Field | Time in UTC timezone when the message was dropped in Target Stream. | |||||
fieldValues | mergeTriggerRecordData/mergeTriggerRecords | Mapped to fieldName CUSTOMER_ID as contatination of messageId |CCId|notificationType|personId | |||||
fieldNames | mergeTriggerRecordData | “Multiple fieldNames nodes with each mapped as following: EMAIL_ADDRESS_ if the campaign type is email MOBILE_NUMBER_ if the campaign type is sms CUSTOMER_ID_ “ | |||||
data | List | ||||||
key | data | Field | optionalData/key | ||||
value | data | Field | optionalData/value | ||||
matchColumnName1 | mergeTriggerRecordData/mergeRule | EMAIL_ADDRESS_ for Email MOBILE_NUMBER_ for SMS. These values are hard coded in the flow. | |||||
matchColumnName2 | mergeTriggerRecordData/mergeRule | null | |||||
insertOnNoMatch | mergeTriggerRecordData/mergeRule | True. Same for Email and SMS | |||||
defaultPermissionStatus | mergeTriggerRecordData/mergeRule | This is the same value sent for Email and SMS. Property name: resp.email.permission | |||||
rejectRecordIfChannelEmpty | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Property name: resp.reject.channel.empty | ||||
optoutValue | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Metadata value to indicate optoutValue. Property name: resp.optout.value | ||||
optinValue | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Metadata value to indicate optinValue. Property name: resp.optin.value | ||||
updateOnMatch | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Property name:resp.update.on.match | ||||
htmlValue | mergeTriggerRecordData/mergeRule | “H” Same for both Email and SMS. | |||||
textValue | mergeTriggerRecordData/mergeRule | “T” value is passed | |||||
matchOperator | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Same for both SMS and Email. Property name: resp.match.operator | ||||
