Responsys CED (EMAIL SENT) | CCB Create Customer Contact API | DVM Mapping | Comments | ||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | ||
CUSTOMER_ID | Field | externalCCId | Field | CUSTOMER_ID contains multiple values delimited by pipe “|” symbol. GUID is mapped to this field. For example: The highlighted value is mapped: “2d343934353135363230323936303338||UNPLN_ERT|0172421206” | |||
CUSTOMER_ID | Field | ccId | Field | CUSTOMER_ID contains multiple values delimited by pipe “|” symbol. CCid is mapped to this field. For example: The highlighted value is mapped: “2d343934353135363230323936303338|1312312|UNPLN_ERT|0172421206” | |||
CUSTOMER_ID | Field | personId | Field | CUSTOMER_ID contains multiple values delimited by pipe “|” symbol. Personid is mapped to this field. For example: The highlighted value is mapped: “2d343934353135363230323936303338||UNPLN_ERT|0172421206” | |||
CUSTOMER_ID | Field | notificationType | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. NotificationType is mapped to this field. For example: The highlighted value is mapped: “2d343934353135363230323936303338||UNPLN_ERT|0172421206” | |||
Field | status | Field | OUTL-BRT-NOTIFHUB_CustContactStatus | ||||
EVENT_CAPTURED_DT | Field | eventCapturedDateTime | Field | ||||
customerContactIdentifier | List | customerContactIdentifier may contain the key value pair. | |||||
RIID | externalRefId | ||||||
C1NS | Value | identifierType | IdentifierType contains C1NS | ||||
customerContactIdentifier | List | CUSTOMER_ID or externalCCid | |||||
CUSTOMER_ID | externalRefId | ||||||
C1EX | Value | identifierType | IdentifierType contains C1EX | ||||
Responsys CED (SMS SENT) | CCB Create Customer Contact API | DVM Mapping | Comments | ||||
CUSTOMER_ID | Field | externalCCId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. GUID is mapped to this field. Example: The highlighted value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
CUSTOMER_ID | Field | ccId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. CCid is mapped to this field. Example: The highlighted value is mapped: "2d343934353135363230323936303338|1312312|UNPLN_ERT|0172421206" | |||
CUSTOMER_ID | Field | personId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. Personid is mapped to this field. Example: The highlighted value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
CUSTOMER_ID | Field | notificationType | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. NotificationType is mapped to this field. Example: The highlighted value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
EVENT_ CAPTURED_DT | Field | eventCapturedDateTime | Field | ||||
Responsys CED (EMAIL FAILED) | CCB Create Customer Contact API | DVM Mapping | Comments | ||||
REASON | reason | Field | |||||
Responsys CED (EMAIL SKIPPED) | CCB Create Customer Contact API | DVM Mapping | Comments | ||||
CUSTOMER_ID | Field | externalCCId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. Guid is mapped to this field. For eg the highlited value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
CUSTOMER_ID | Field | ccId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. CCid is mapped to this field. For eg the highlited value is mapped: "2d343934353135363230323936303338|1312312|UNPLN_ERT|0172421206" | |||
CUSTOMER_ID | Field | personId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. Personid is mapped to this field. For eg the highlited value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
CUSTOMER_ID | Field | notificationType | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. NotificationType is mapped to this field. For eg the highlited value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
customerContactIdentifier | List | ||||||
RIID | externalRefId | customerContactIdentifier may contain the key value pair. | |||||
C1NS | Value | identifierType | |||||
customerContactIdentifier | List | IdentifierType contains C1NS | |||||
CUSTOMER_ID or externalCCid | |||||||
Responsys CED (SMS SKIPPED) | CCB Create Customer Contact API | DVM Mapping | Comments | ||||
Pending File (xml ) | CCB Create Customer Contact API | DVM Mapping | Comments | ||||
messageId | Field | externalCCId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. Guid is mapped to this field. For eg the highlited value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
notifEventInstanceId | notificationInstanceId | ||||||
CCId | Field | ccId | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. CCid is mapped to this field. For eg the highlited value is mapped: "2d343934353135363230323936303338|1312312|UNPLN_ERT|0172421206" | |||
origin | OUTL-BRT-NOTIFHUB_OriginSystem | ||||||
accountId | accountId | ||||||
contactId | contactId | ||||||
notifPreferenceId | notificationPreferenceId | ||||||
deliveryChannel | deliveryChannel | ||||||
deliveryValue | deliveryValue | ||||||
notificationType | Field | notificationType | Field | CUSTOMER_ID contains multiple values delimited by pipe "|" symbol. NotificationType is mapped to this field. For eg the highlited value is mapped: "2d343934353135363230323936303338||UNPLN_ERT|0172421206" | |||
emailSubject | emailSubject | ||||||
eventCapturedDateTime | Field | eventCapturedDateTime | Field | This is the datetime in UTC timezone of when the message was dropped in TargetNotificationStream | |||
messageId | Field | externalRefId | |||||
data | List | data | List | CUSTOMER_ID or externalCCid | |||
key | Field | key | |||||
value | Field | value | IdentifierType contains C1EX | ||||
sourceMessageId | Field | externalRefId | This contains the NMS voilation id that is the system Originating id. This is applicable for NMS notification only. | ||||
C1OS | Value | identifierType | Originating System Identifier | ||||
Responsys CED (SMS FAILED) | CCB Create Customer Contact API | DVM Mapping | Comments | ||||
