OCI Stream | Responsys SFTP Pending File | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM | Source Column | Target Column | |
messageId | Field | messageId | Field | ||||||
origin | Field | origin | Field | ||||||
accountId | Field | accountId | Field | ||||||
notificationType | Field | notificationType | Field | ||||||
cisDivision | Field | cisDivision | Field | ||||||
contactId | Field | contactId | Field | ||||||
personId | Field | personId | Field | ||||||
language | Field | language | Field | ||||||
lastName | Field | lastName | Field | ||||||
firstName | Field | firstName | Field | ||||||
deliveryChannel | Field | deliveryChannel | Field | ||||||
deliveryValue | Field | deliveryValue | Field | ||||||
notificationTemplate | Field | notificationTemplate | Field | ||||||
deliveryInstance | Field | deliveryInstance | Field | ||||||
CCId | Field | CCId | Field | ||||||
notifPreferenceId | Field | notifPreferenceId | Field | ||||||
optOutAllowed | Field | optOutAllowed | Field | ||||||
custContactNeeded | Field | d | Field | ||||||
subscriptionType | Field | subscriptionType | Field | ||||||
notifEventInstanceId | Field | Id | Field | ||||||
sourceMessageId | Field | sourceMessageId | Field | ||||||
timezone | Field | timezone | Timezone is not convered based on the DVM (OUTL-BRT-NOTIFHUB_Timezones) and other integration will already do the conversion. The Json message from OCI stream already has the converted timezone for example this field will have EST as time zone but note USEstern (CCB type timezone) | ||||||
emailSubject | Field | emailSubject | Field | OUTL-BRT-NOTIFHUB_NotifMetaData | EmailSubject | ||||
eventCapturedDate Time | Field | eventCapturedDateTime | Field | This is the UTC Timezone datetime when the message was dropped in TargetNotificationStream | |||||
data | List | data | List | ||||||
key | Field | key | Field | ||||||
value | Field | value | Field | ||||||
