Property Name | Value | Description |
from | nms-ofsc-administrator@yourdomain.com | Specify where the error email will be sent from. |
to | mailID@yourdomain.com | Specify where the error email will be sent to. |
ofsc.bucket | OHMeter | Default OFS work bucket that is linked to this NMS instance |
source.system | NMS | Used in several integrations to denote where the request is coming or going to. |
activities.linktype | related_activity2 | Default value |
failedEquipment.props | No longer used | |
failedEquipment.enumProps | MANUF_TEXT RATING_UNITS_OM THREE_PH_TOGGLE SINGLE_PH_TOGGLE | Denote what properties require extra processing in OFS to complete the form formats. |
failedEquipment.dateProps | No longer used | |
ofs.language | en | Default value of OFSC request for language. |
workSkill.sharing.default | summary | Default value |
workSkillProperty.type.default | string | Default value |
workSkillProperty.entity.default | activity | Default value |
workSkillProperty.gui.default | text | Default value |
workSkillProperty.nameSuffix.default | needed | Default value |
workSkillCond.actvtySameSkillMaxWorker.default | 1 | Default value |
workSkillCond.function.default | in | Default value |
activeFlag.default | true | Default value |
bucket.timeZone.default | America/New_York | Default timezone in OFS |
parentBucket.default | UGBU | Top level OFS bucket |
ofsc.controlZone | 3 | Depth of zones that will be synced and used to assign activities |
ofsc.useControlZoneFromNMS | true | Use the NMS provided controlzones for preassigned activities |
ofsc.resourceDetail.loopLimit | 100 | The amount of OFS resource read at once during traversing all resources. |
ofsc.workZone.default.NMSncgClass | 4802 | Default work bucket value in NMS |
ofsc.workZone.default.status | active | Default value |
ofsc.workZone.default.travelArea | sunrise_enterprise | Default value for a workzone travel area |
ofsc.workZone.default.Fuzzy Type | NO_OUTAGE | NMS value for workzone during admin sync process |
failedEquipment.nms.tableName | PICKLIST_INFO_EQ_ FAIL | Failed Equipment schema name in NMS GetAdminData request |
nms.crew.outOfRange | false | Default flag during crew updates in NMS |
nms.crew.isAvailForOp | true | Default flag during crew updates in NMS |
nms.crew.isMobileIntegrated | true | Default flag during crew updates in NMS |
notification.chat.assertion | {JWT-Token} | JWT token received from creating assertion and used to request an OFS Access Token |
notification.chat.grantType | urn:ietf:params:oauth:grant-type:jwt-bearer | Grant Type used in conjunction with jwt token to request the OFS Access Token |
ofsc.resourceType.FieldResource | field_resource | Value of OFS ResourceType used when sending to NMS |
notification.type.chat | chat | Notification value for chat |
notification.type.email | email | Notification value for email |
notification.email.flag | true | Denotes if email notification to be sent if error occur |
notification.chat.flag | true | Denotes if chat notification to be sent if error occur |
ofsc.isScheduledForPreAssignedCrew | true | Default value |
ofsc.setPositionInRoute | notOrdered | Default value |
nms.adminSync.EventCategories | true | Process this phase during Admin Sync? |
nms.adminSync.Failed Equipment | true | Process this phase during Admin Sync? |
nms.adminSync.Phases | true | Process this phase during Admin Sync? |
nms.adminSync.Manufacturers | true | Process this phase during Admin Sync? |
nms.adminSync.CrewTypes | true | Process this phase during Admin Sync? |
nms.adminSync.ControlZones | true | Process this phase during Admin Sync? |
nms.adminSync.WorkZones | true | Process this phase during Admin Sync? |
nms.adminSync.CustomerTypes | true | Process this phase during Admin Sync? |
nms.adminSync.EventType Categories | true | Process this phase during Admin Sync? |
notification.chat.default Dispatcher | {ofs default dispatcher} externalID | Default dispatcher that will receive error chats on generic requests |
dateTimeFormat.default.OFS | [Y0001]-[M01]-[D01] [H01]:[m01]:[s01] | Default datetime format for OFS |
dateTimeFormat.default.NMS | [Y0001]-[M01]-[D01]T[H01]:[m01]:[s01].000Z | Default datetime format for NMS |
failedEquipment.oic.Lookup Name | OUTL-BRT-NMS_OIC_FailedEquipCaching_DND | Name of cached failed equipment lookup, used for performance |
eventTypeCategory.oic.Lookup Name | OUTL-BRT-NMS_OIC_EventTypeCategoryCaching_DND | Name of cached EventTypeCategory lookup, used for performance |
findInstance.oic.LookupName | OUTL-BRT-NMS_OFSC_InstanceIDToBucket | Name of DVM to retrieve the NMS instance from an OFS resource |
findInstance.oic.LookupSource ColumnName | OFSC_BucketID | Name of the source column that contains the OFS configured bucket |
findInstance.oic.LookupTarget ColumnName | NMS_ConnectionID | Name of the target column that points to the NMS connection instance |
findInstance.oic.LookupNotFoundValue | NotFound | Value if the OFS Resource cannot be found returned by the Find Resource Bucket integration |
attachment.nms.limit | 10 | Number if NMS Operator allowed attachments |
attachment.ofs.limit | 10 | Number if OFS Operator configured attachments |
attachment.nms.file.prefix | nms_sourced_attachment_ | NMS attachment prefix inside OFS customized fields |
operatorComments.eventDetails | Event Details updated [system-generated] | Static operator comment message when OFS forms were triggered |
operatorComments.failedEquipment | Failed Equipment updated [system-generated] | Static operator comment message when OFS forms were triggered |
NMS_InstanceID | OFSC_BucketID | NMS_InstanceURL | NMS_InstanceID |
NMS- | OHMeter | URL pointing to NMS instance | OUTL-BRT-NMS1_NMSOFSC |
OFSC_EventType | NMS_ActivityStatus | NMS_ActionCode |
activityCreated | Initial | CREATE |
activityStarted | STARTED | UPDATE |
activitySuspended | SUSPENDED | UPDATE |
activityNotDone | CANCELLED | UPDATE |
activityCompleted | COMPLETE | UPDATE |
activityCanceled | CANCELLED | UPDATE |
activityUpdated | UPDATE | |
activityMoved | DISPATCHED | UPDATE |
activityTravelStarted | EN_ROUTE | UPDATE |
activityTravelStopped | DISPATCHED | UPDATE |
NMS_ActivityEventStatus | NMS-OFSCActivityStatus | OFSC_ActivityStatusNew |
STARTED:SUS | suspended | |
SUSPENDED:SUS | suspended | |
CANCELLED:started | notdone | |
CANCELLED:enroute | notdone | |
CANCELLED:cancelled | ERROR:Activity already in cancelled status in OFS | |
CANCELLED:notdone | ERROR:Activity already in notdone status in OFS | |
CANCELLED:completed | ERROR:Activity already in completed status in OFS | |
CANCELLED: | ERROR:No matching OFS activity status found | |
CANCELLED:pending | cancelled |
NMS_ActivityType | OFSC_ActivityType | Description |
NMS_Trouble | NMS_Trouble | Default Value |
