Property Name | Sample Value | Description |
email.flag | true | Flag to indicate to send out email notifications |
maxerrorcount.per. emailnotification | 50 | An email notification is sent after the maximum number of records in error set here is reached. It will keep sending an email notification for every interval of the maximum error count. Example: There are 150 records to be processed and this property is set to 50. When the process reached it's 50th error record then an email notification listing the 50 error records is sent. For every 50 error records an email notification is sent. |
wacs.externalsystem | GD_INT_ERP | This value is obtained in WACS. This must be a valid expense code in WACS. |
wacs.usageexpensecode. default | DK_USG_EXP | This value is obtained in WACS. This must be a valid expense code in WACS. |
erp.purchase.itemcategory | Purchasing | This is the Purchase item Category defined in ERP. This is used to get the category name to be mapped to WACS Purchase Commodity field. |
erp.assetactivity.useritem typevalue | Asset Activity | This is the Asset activity User Item Type defined in ERP. This is used in the WACS repairable mapping. |
