Integration Overview
Oracle Utilities Work and Asset Cloud Service Integration to Oracle ERP Product Hub Cloud synchronizes stock items from Oracle ERP Product Hub Cloud to Oracle Utilities Work and Asset Management for new and updated items.
The following diagram provides a high-level representation of the integration: Illustrates the business processes supported in this integration product.
The advantages of this integration are:
• Enables maintaining information pertaining to a Items in Oracle ERP Product Hub Cloud as central repository and Master for both systems.
• Smart View report or Oracle Transactional Business Intelligence Analyses can be done for Item process in Oracle ERP Product Hub Cloud.
• Audit Capability in both system is available.
• Seamless integration between two products.
• Easy and quick deployment.
• Reduces IT and administrative costs.
The mapping of fields attributes for some fields are direct and for some DVM are required for records creation in Oracle Utilities Work and Asset Management.
The integration will support Bulk upload and incremental updates to Oracle Utilities Work and Asset Management.
• BULK /INITIAL Upload
• Incremental Upload
For more information about the integration, refer to the Oracle ERP Product Hub Cloud Integration to Oracle Utilities Work and Asset Cloud Service for Stock Item Configuration Guide included in this release.
