Introduction
This integration provides the ability for a customer to manage all the item information and details in one primary instance (Oracle ERP Product Hub) and communicate with Oracle Utilities Work and Asset Cloud Service:
• Oracle ERP Product Hub will be the master for all Item information.
• This seamless integration between Oracle ERP Product Hub and Oracle Utilities Work and Asset Cloud Service helps to have the same Item definition across both platforms.
• The integration will support Bulk upload and incremental updates to Oracle Utilities Work and Asset Cloud Service.
• Bulk Upload: Oracle ERP Product Hub to Oracle Utilities Work and Asset Cloud Service
• Incremental Update: Oracle ERP Product Hub to Oracle Utilities Work and Asset Cloud Service
The goals for Oracle ERP Product Hub to Oracle Utilities Work and Asset Cloud Service one-directional interface are to make sure that there is a seamless integration between Oracle ERP Product Hub and Oracle Utilities Work and Asset Cloud Service:
• To make sure the items are synchronized.
• To make sure Oracle ERP Product Hub is the source of record for Items and Item attributes.
• To make sure Oracle Utilities Work and Asset Cloud Service is always a mirror image of Oracle ERP Product Hub.
• To document all required columns to be mapped between Oracle ERP Product Hub and Oracle Utilities Work and Asset Cloud Service.
