Managing Web Service Catalog
The web service catalog is used by Oracle Integration Cloud to communicate with the respective application. It is used to identify the services that should be retrieved by the Oracle Utilities Adapter. It is configured in Catalog URL in the Oracle Integration Cloud connection.
To configure the catalog in Oracle Utilities Work and Asset Cloud Service:
1. Login to Oracle Utilities Work and Asset Cloud Service.
2. Navigate to the Web Service Catalog page either from the Admin > [W or Integration] menu or from the Search menu.
3. Select REST Web Service Class.
4. Add the REST inbound web services mentioned below to the catalog.
5. For outbound messages, add the External System that was set up previously.
For more information about configuration, refer to the Oracle Utilities Work and Asset Cloud Service documentation on Oracle Help Center at:
https://docs.oracle.com/en/industries/energy-water/work-asset-cloud-service/index.html.
