Table Name | drms_parameters |
OIC flow end point URL | • Update the value with OIC flow end point URL <https://hostname:port /ic/api/integration/v1/flows/oracleutilities/OUTL-BA-DRMS_DACS_DEV_STAT_ACK/1.0/status-check-ack-to-dacs where the attrib = 'OIC_STATUS_ACK_URL' • Update the value with OIC flow end point URL <https://hostname:port/ ic/api/integration/v1/flows/rest/OUTL_BA_DRMS_DACS_EVT_DVCRESV/1.0/reserveDevice> where the attrib=' OIC_RESERVE_DEVICE_URL' • Update the value with OIC flow end point URL <https://hostname:port /ic/api/integration/v1/flows/rest/OUTL_BA_DRMS_DACS_PRE_EVENT_CANC/1.0/preEventCancel where the attrib = 'OIC_EVENT_CANCEL_URL' • Update the value with OIC flow end point URL <https://hostname:port ic/api/integration/v1/flows/oracleutilities/OUTL-BA-DRMS_DACS_ENROLLRQ/1.0/enroll-to-dacs where the attrib = 'OIC_ENROLL_URL' • Update the value with OIC flow end point URL <https://hostname:port/ic/api/integration/v1/flows/rest/OUTL-BA-DRMS_DACS_EVT_OUTC_TRNFR/1.0/eventOutcome where the attrib = 'OIC_EVENT_OUTCOME_DACS_URL' • Update the value with < OIC_USER Name> where the attrib=' OIC_USER' • Update the value with <oic password> where the attrib=' OIC_PASS ' |
MAX_RETRIES | • The value to be set to the amount of retries DERMS will perform upon receiving a technical fault or negative acknowledgment. • The drms_outbound_messages database table holds the outbound messages to be resent when the status = ‘FAIL’ and the num_retries is less than the configured MAX_RETRIES value. If you want to resend a failed message that has already retried the maximum number of times, update the num_retries record back to 0. If you need to resend a successful message for any reason, also update the status to ‘FAIL’. |
