Property Name | Sample Value | Description |
dacs.dvcScore.extract.filename.prefix | SDCSE | Device Score Extract file name prefix. It should have the same value as the batch parameter filename in Batch Process X1-SDCSE. |
dacs.dvcScore.ftp.input.directory | /scratch/sploutput/ VMAIN_C2M_DACS_DERMS_LIN_ORA_WLS/tmp | DACS directory where the device score extract files are stored and for OIC to pick up from. Required to populate this when DACS is on-premises. |
dacs.os.dvcScore.bucket name | DACS_DERMS_DEVICE_SCORE | DACS Device Score Bucket Name to where the objects or files are stored. Define the bucket name where the Device Score Extract files are stored. It is used while calling the Object Storage APIs. Required to populate this when DACS is in the cloud. |
dacs.os.namespace | idabowt3caih | DACS Object Storage namespace serves as a container for all your buckets and objects. Defines the namespace where the buckets and objects the Device Score extract file resides. It is used while calling the Object Storage APIs. Required to populate this when DACS is in the cloud. |
dacs.prefixtag.filenot uploaded | Error- | The text to append to the filename to mark the file as error or not uploaded in NMS-DERMS. |
dacs.prefixtag.fileuploaded | Sent- | The text to append to the filename to mark the file as processed or uploaded in NMS-DERMS. Shared property for all flows in this integration. |
email.flag | TRUE | If error email notification should be sent out. Valid values are true and false. |
enrollmentSyncAckDelay | 5 | |
notification.email.flag | TRUE | |
notification.type.email | Email |
Property Name | Value | Description |
PENDING | SUCCESS | |
ERROR | ERROR | |
VALERROR | ERROR | |
FAILURE | ERROR | |
10589 | SUCCESS |
DRMS_EVENT_OUCOME | DACS_EVENT_OUTCOME | Name | Description |
0 | D1SP | successfulParticipation | Successful participation |
1 | D1CN | cancelledOutcome | Cancelled |
2 | D1ER | errorOutcome | Error |
3 | D1IO | inFlightOverride | In-flight override |
4 | D1ND | nonResponsiveDevice | Non-responsive device |
ouai.os.enrollack.bucket | OUAI_EnrollAck_DEV | The OS bucket where integration will poll the file to process the enrollment sync acknowledgment files. This is the location where OUAI will be placing the sync ack file. |
ouai.os.enrollack.filename.prefix | feedback.dacs.program_subscription | File name prefix format OUAI will be generating the enrollment sync acknowledgment files. The filename can contain date time including milliseconds. |
ouai.os.enrollack.filename.prefixtag.sent | sent_ | OIC uses this value to prefix the processed enrollment sync acknowledgment file once all the messages in the file are processed. |
ouai.dacs.messasge.number | 11220 | DACS message number. This is used to send back the message number to DACS on any error received from OUAI while processing the enrollment sync. |
ouai.dacs.messasge.category | 11104 | DACS message category. This is used to send back the message category to DACS on any error received from OUAI while processing the enrollment sync. |
from | The email address used to send any error notification. | |
to | The email address or group used to receive any error notification. |
