Oracle Integration Cloud
This section focuses on the monitoring Oracle Integration Cloud and troubleshooting any issues that occur during the integration activation.
Monitoring Integration Flows
Integration flows are monitored using the following:
Dashboard
Cloud Logs
To monitor the integration flows from the Oracle Integration Cloud dashboard:
1. Login to Oracle Integration Cloud.
2. On the Home page, click Monitoring.
3. Select any of the following as required:
Dashboards - To monitor the complete dashboard of integration.
Integrations - To monitor each integration.
Tracking - To monitor instance and flow trace/activity stream of the integration.
Error - To monitor the integrations in ‘error’ state. Re-submit the asynchronous integration flows.
To monitor the integration flows using Oracle Integration Cloud logs:
3. On the navigation pane, click Dashboards to view the overall success/failure rate of the integration.
4. Navigate to the Logs menu.
5. In the right pane, click the link to show options for downloading the Oracle Integration Cloud logs or diagnostics logs.
6. In case of any issues, attach the diagnostic logs to a service request for help.
Troubleshooting
If an activation fails, the Integrations page displays an error message.
To troubleshoot the activation error:
1. Click Download Diagnostic Logs to download the logs for diagnosing the issue.
2. Select Enable Tracing.
TRACE ENABLED is displayed next to ACTIVE.
A few sample cases are as follows:
For any connectivity errors while activating the integration, make sure the trigger connection is successful. Test the connection and refresh the metadata, and then activate the integration.
If the integration (Oracle Utilities Network Management System initiated flows) is activated for the first time, make sure the Oracle Utilities Network Management System catalog is configured accurately.
