Testing the Integration Flows
The following table lists the integration end point URLs and the respective applications in which these endpoints need to be configured. Configure the same and perform end-to-end testing.
Integration Name
End Point URL to be Configured
Application to be Configured
Oracle Utilities CCB OCI Stream Notif Upload
https://OIC_Host:OIC_Port/ ic/api/integration/v1/flows/oracleutilities/OUTL-BA-CCB_STREAM_NOTIF_UPLOAD/1.0/notifications
Note: If the base flow is cloned for customization and the customized flow is used, replace OUTL-BA- CCB_STREAM_NOTIF_UPLOAD in the URL with identifier of the cloned flow.
Oracle Utilities Customer Care and Billing
