Creating Profile List and Zero-Record Filter
The default profile list will determine where customer records, also referred to as profiles, will be stored.
To create a profile list and a zero-record filter:
1. Create a profile list with the default schema. Navigate to Profile Lists and click Create New List.
2. Select the appropriate name from the
Brand drop-down list. Select
CM_OU_Campaign from the
Folder drop-down list.
![](../NH-SETUP-GUIDE-23A/images/select-brand-and-folder-1chap3.png)
3. Create a zero-record filter. From the
Create Filter drop-down list, select
Profile data.
![](../NH-SETUP-GUIDE-23A/images/select-Create-Filter-and-Profile-data-2chap3.png)
4. Populate the fields in the
Profile attributes section. Enter the condition “
RIID_ is equal to 1” (as shown below) and click
Save to update data in the
CM_OU_Campaigns folder.
![](../NH-SETUP-GUIDE-23A/images/enter-condition-CM_OU_Campaigns-folder-3chap3.png)
5. The
Profile List and
Zero Record folder will be displayed as below.
![](../NH-SETUP-GUIDE-23A/images/profile-list-and-zero-record-folder-4chap3.png)
6. Delete the filters that are not necessary for the functionality.
