Configuring Connections in Oracle Integration Cloud
After the packages are imported and verified, configure the respective connections.
This section describes the procedure to set up the following connections:
• Oracle Utilities REST NMS1 for NMS-OFSC
• Oracle Utilities REST API NMS for NMS-OFSC
• Oracle Utilities REST OFSC for NMS-OFSC
• Oracle Utilities REST API OFSC for NMS-OFSC
• Oracle Utilities REST OIC for NMS-OFSC
• Oracle Utilities REST for NMS-OFSC
Configuring Oracle Utilities REST NMS1 for NMS-OFSC
This connection is used to trigger from or invoke to the Oracle Utilities Network Management System using the Oracle Utilities Adapter.
To configure the connection:
1. From the Connection Properties, enter the Oracle Utilities Network Management System catalog URL.
2. Enter "https://{NMS-Host}:{NMS-Port}/nms-ofs/rest/v1/catalog" in the Catalog URL field.
3. From the Security Policy drop-down list, select Basic Authentication.
4. Configure the Username and Password fields.
5. Configure the appropriate Agent Group.
6. On the Connection page, click Test.
7. After the connection is tested successfully, click Save.
This connection is used by the following integrations:
• Oracle Utilities NMS OFSC Activity Async Processor
• Oracle Utilities NMS OFSC Admin Sync
• Oracle Utilities NMS OFSC Ping
• Oracle Utilities OFSC NMS Activity Create
• Oracle Utilities OFSC NMS Activity Update
• Oracle Utilities OFSC NMS Attachments
• Oracle Utilities OFSC NMS Event Details Update
• Oracle Utilities OFSC NMS Failed Equipment Update
• Oracle Utilities OFSC NMS Resource Create Update
• Oracle Utilities OFSC NMS Resource Route
• Oracle Utilities OFSC NMS Resources Sync
Configuring Oracle Utilities REST API NMS for NMS-OFSC
This connection is used to communicate with Oracle Utilities Network Management System using REST adapter.
Configure the Oracle Utilities Network Management System connection with the required details:
1. From the Connection Type drop-down list, select REST API Base URL.
2. Select the TLS Version as TLSV1.2.
3. Enter "https://{NMS-Host}:{NMS-Port}/nms-ofs/rest/v1" in the Connection URL field.
4. From the Security Policy drop-down list, select Basic Authentication.
5. Configure the Username and Password fields respectively from the Oracle Utilities Network Management System application.
6. Configure the appropriate Agent Group.
7. On the Connection page, click Test.
8. After the connection is tested successfully, click Save.
This connection is used by these integrations:
• Oracle Utilities NMS OFSC Attachment
Configuring Oracle Utilities REST OFSC for NMS-OFSC
This connection is used to communicate with Oracle Field Service using the Oracle Field Service adapter via a trigger or invoke.
Configure the Oracle Field Service connection with the required details:
1. Enter the API URL in the Oracle Field Service API URL field.
2. Enter the Instance ID.
4. On the Connection page, enter the username and password. Click Test.
Note: Make sure to configure the client and client secret part of the username and password. Retrieve them by logging into Oracle Field Service.
5. After the connection is tested successfully, click Save.
Configuring Oracle Utilities REST API OFSC for NMS-OFSC
This connection is used to sync invoke or get triggered from OFSC API using the REST adapter.
Configure the Oracle Utilities REST OFSC for NMS-OFSC connection with required details:
3. Enter "https://api.etadirect.com/rest" in the Connection URL field.
5. Configure the client ID and client secret in the Username and Password fields respectively from the Oracle Field Service application.
Note: The username should be in the following format: Client_id@instance id
6. On the Connection page, enter the username and the password. Click Test.
Note: This connection is used by the following processes:
• Oracle Utilities NMS OFSC Chat Notification
• Oracle Utilities OIC OFSC Find Resource Bucket
Configuring Oracle Utilities REST OIC for NMS-OFSC
This connection is used to communicate with Oracle Integration itself using REST adapter.
2. Select "TLSV1.2" as the TLS Version.
3. Enter "https://{OIC-Host}:{NMS-Port} in the Connection URL field.
5. Configure the Username and Password fields respectively from the OIC instance.
Note: This connection is used by the following integrations:
Configuring Oracle Utilities REST for NMS-OFSC
This connection is used to design local integrations entry point and invoke these within Oracle Integration Cloud using the REST adapter.
1. Select Basic Authentication and Role as Trigger.
2. Click Save.
• Oracle Utilities NMS OFSC Activity Process
• Oracle Utilities NMS OFSC Common Error Handler
