Supported Applications
The supported application versions in this integration are:
• Oracle Integration Cloud (OIC): V23.1.3.0.0 or higher
• Oracle Utilities Network Management System: V2.6.0.0.2 or higher
• Oracle Field Service: 23A or higher
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
