Batch Code | Batch Process Description |
F1-SYNRQ | Transitions all the sync requests out of the PENDING state. |
F1-SAKRQ | Pre-allocates the production key to each record and transitions all the sync requests out of the Transformed/Schema Validated state into the Key Allocated state. |
W1-SIKCN | Resolves any foreign keys within the schema as well as executes the validation algorithms on the target business objects. This batch code is for processing Contact initial sync requests. |
W1-SILCN | Loads the records for Contact into the production tables. |
W1-SIKSP | Resolves any foreign keys within the schema as well as executes the validation algorithms on the target business objects. This batch code is for processing service point initial sync requests. |
W1-SILSP | Loads the records for service point into the production tables. |
W1-SILDD | Transitions all initial sync requests into the Additional Processing state from the Loaded state. An algorithm in the Additional Processing state sends an acknowledgment back to the external system along with the production ID of the synchronized object in Oracle Utilities Operational Device Management. |
W1-SIIER | Transitions sync request out of the ERROR state. |
