Example Outbound Message Types for Integration Points
Outbound Message Type for Asset -Device Sync
Description
Business Object
DM-OMT-DEF
Device Sync Response Outbound Message Type
D1-OngoingSyncReqAckMsg
Outbound Message Type for SP-Node Configuration Sync
Description
Business Object
D1-SPOUTMSG
Operational Device Management Service Point Outbound Message
D1-OutboundMessage
Outbound Message Type for Contact Sync
Description
Business Object
D1-CONOUTMSG
Operational Device Management Contact Outbound Message
D1-OutboundMessage
Outbound Message Type for Install Event - Asset Node Sync
Description
Business Object
D1-IEOUTMSG
Operational Device Management Install Event Outbound Message
D1-OutboundMessage
External System
To create a new external system to support the integration:
1. Navigate to Admin > E > External System.
2. Enter a unique external system and description.
For example: Name = ODM_ICS, Description = Oracle Utilities Operational Device Management
3. Set the Our Name in Their System field to MDM.
4. Associate the outbound message types created to the external system.
5. For each outbound message type, set the following:
• Outbound Message Type - Set the outbound message type created for Oracle Utilities Meter Data Management outbound process.
• Processing Method - Real-time
• Message Sender - Set the message sender created for the process.
• Date/Time Format - XSD
• Namespace Option - Configured on Sender
For example: External System - ODM_ICS
