Oracle Utilities Meter Data Management Services
Install Event - Asset Node Synchronization
This process synchronizes asset node details required by Oracle Utilities Operational Device Management from install event in Oracle Utilities Meter Data Management.
The following diagram provides a graphical representation of this processing:
Business Processing
The Install Event - Asset Node Sync request integration process includes the following activities:
1. Oracle Utilities Meter Data Management sends the Install Event sync information in the form of XML messages to the Install Event sync request integration process Oracle Utilities Meter Data Management-Operational Device Management Install Event Sync which is deployed on Oracle Integration Cloud.
2. The request integration process transforms Install Event request messages in the Oracle Utilities Meter Data Management format to Asset Node messages in the Oracle Utilities Operational Device Management format and invokes W1-SyncRequestInboundAssetNode inbound web service in Oracle Utilities Operational Device Management.
3. An immediate acknowledgment is sent to Oracle Utilities Meter Data Management.
4. Any errors are reported back to Oracle Utilities Meter Data Management through the global fault handler.
5. An email notification with error details will be sent to the users configured in the OUTL-BRT-ODM_MDM_Email lookup.
The Install Event - Asset Node Sync response integration process includes the following activities:
1. After running the batch job in Oracle Utilities Operational Device Management, Asset Node sync response in the form of XML messages are sent to the Asset Node sync response integration process Oracle Utilities Operational Device Management-Meter Data Management Install Event Sync Resp which is deployed on Oracle Integration Cloud.
2. The response integration process transforms the Asset Node response message in the Oracle Utilities Operational Device Management format to Install Event message in the Oracle Utilities Meter Data Management format and invokes F1-UpdateAndTransitionSyncRequest inbound web service in Oracle Utilities Meter Data Management.
3. An immediate acknowledgment is sent to Oracle Utilities Operational Device Management.
4. Any errors are reported back to Oracle Utilities Operational Device Management through the global fault handler.
Technical Details
This section provides the integration process, as well as Oracle Utilities Meter Data Management and Oracle Utilities Operational Device Management inbound web services used for the Install Event - Asset Node Synchronization integration point.
