Table Name | drms_parameters |
OIC flow end point URL | Update the value with OIC flow end point URL • <https://hostname:port/ic/api/integration/v1/flows/rest/OUTL-BA-DRMS_OUAI_EVT_OUTC_TRNFR/1.0/eventOutcome where the attrib = 'OIC_EVENT_OUTCOME_OUAI_URL' |
OIC Credentials | The <OIC_USER> and <OIC_PASS> should already be configured from the implemented DACS-DERMS package. |
MAX_RETRIES | • This should already be configured from the implemented DACS-DERMS package. Value to be set to the amount of retries DERMS will perform upon receiving a technical fault or negative acknowledgment. • The drms_outbound_messages database table holds the outbound messages to be resent when the status = ‘FAIL’ and the num_retries is less than the configured MAX_RETRIES value. If you want to resend a failed message that has already retried the maximum number of times, update the num_retries record back to 0. If you need to resend a successful message for any reason, also update the status to ‘FAIL’. |
