Property Name | Sample Value | Description |
dacs.file.transfer.pref | os | Default type of file transfer. Values are “os” or “ftp” |
dacs.enroll.filename.prefix | ENROLL_SYNC | EnrollmentSync extract file name prefix for ftp transfer. It should have the same value as the batch parameter filename in Batch Process X1-DACEX or X1-DACIL |
dacs.ftp.enroll.input.directory | /scratch/sploutput/VMAIN_C2M_DACS_DERMS_LIN_ORA_WLS/tmp/ | DACS directory where the EnrollmentSync extract files are stored in the ftp server for OIC to pick up. Required to populate this when DACS is on-premises |
dacs.ftp.kwhavoid.input.directory | /scratch/Integration/KWH | DACS directory where the KwhAvoided extract files are stored in the ftp server for OIC to pick up. Required to populate this when DACS is on-premises. |
dacs.os.enroll.bucket | DACS_Source_DEV | DACS directory where the EnrollmentSync extract files are stored and for OIC to pick up. Required to populate this when DACS is configured for ‘os’ file processing |
dacs.os.kwhavoided.bucket | OUAI_Target_DEV | DACS directory where the KwhAvoided extract files are stored in the object storage for OIC to pick up. Required to populate this when DACS is configured for ‘os’ file processing |
dacs.os.namespace | idabowt3caih | DACS Object Storage namespace serves as a container for all your buckets and objects. Defines the namespace where the buckets and objects the Device Score extract file resides. Required to populate this when DACS is configured for ‘os’ file processing |
dacs.prefixtag.fileuploaded | Sent- | Prefix used to rename the extract filename that has been transferred correctly |
notification.email.error.flag | true | Determines if error email notifications are sent out when technical errors occur. By default, this is set to “true” |
notification.email.process.complete.flag | true | Determines if processes completed notifications are sent out to application users after th OIC process ends. by default, this is set to “true” |
notification.email.process.nofile.flag | true | Hardcoded value, used by the integrations to verify if a business email must be sent even when no files were present during the scheduled time |
notification.type.email | email | Hardcoded value for the integrations to send to the ‘common error handler’ to decide how to send the notifications out. In future release this might be augmented with other types beside of ‘email’ |
ouai.file.target.transfer.pref | os | Default type of file transfer. Values are “os” or “ftp” |
ouai.loadreductionforecast.filename.prefix | LRRF_ | LoadReductionForecast extract file name prefix for file transfer |
ouai.os.enroll.bucket | OUAI_EnrollmentSync | OUAI directory where the EnrollmentSync extract files are stored. Required to populate this when OUAI is configured for ‘os’ file processing |
ouai.os.eventoutcome.bucket | OUAI_EventOutcome | OUAI directory where the Event Outcome extract files are stored. Required to populate this when OUAI is configured for ‘os’ file processing |
ouai.os.kwhavoided.bucket | OUAI_ KwhAvoided | OUAI directory where the KwhAvoided extract files are stored. Required to populate this when OUAI is configured for ‘os’ file processing |
ouai.os.kwhavoided.filename.prefix | KwhEvent | KwhAvoided extract file name prefix for file transfer |
ouai.os.loadreductionforecast.bucket | OUAI_LoadReduction | OUAI directory where the LoadReductionForecast extract files are stored. Required to populate this when OUAI is configured for ‘os’ file processing |
ouai.os.namespace | idabowt3caih | OUAI Object Storage namespace serves as a container for all your buckets and objects. Defines the namespace where the buckets and objects extract file resides. Required to populate this when OUAI is configured for ‘os’ file processing |
ouai.prefixtag.fileuploaded | SENT_ | Prefix used to rename the extract filename that have been transferred or processed correctly |
Recipient | Email ID | Description |
from | admin@myCy.com | Default email ‘from’ address on all outgoing emails for this package |
to | errorDist@myCy.com | Comma separated email addresses that will receive the technical error notifications |
dacs.to.process.notification | dacsUser@myCy.com | Comma separated email addresses of DACS business or application users that will receive the business notifications for DACS related integrations |
ouai.to.process.notification | ouaiUser@myCy.com | Comma separated email addresses of OUAI business or application users that will receive the business notifications for OUAI related integrations |
drms.to.process.notification | drmsUser@myCy.com | Comma separated email addresses of DRMS business or application users that will receive the business notifications for DRMS related integrations |
