Scheduling the Batch Process
Schedule the W1-ERPFA batch job to generate asset extract file. It has a couple of parameters that can be used to control which synchronization request should business objects process.
W1-ERPFA: This batch process is responsible for generating the asset extract file for ERP fixed/project assets when an asset is created/updated/removed in Oracle Utilities Work and Asset Cloud Service.
The batch job should be scheduled to run with the following job parameters:
Batch code: W1-ERPFA
fileIntegrationType: W1-ERPFAExtract
fileName: ERPFA_{BC}{BN}{TN}.csv
filePath: tmp/ (this is the relative path)
fileFormat: CSV
