DVM Name | Description |
OUTL-BRT-WACS_ERPFA_OWNINGACCESSGROUP | Used to map Owning access group from WACS with Asset Book type code and Asset book name in ERPFA. |
OUTL-BRT-WACS_ERPFA_CONFIGPROPS | Used to configure the integration properties. Maps PropertyName column to the respective Value column. Note: Do not change the values under the PropertyName column. |
OUTL-BRT-WACS_ERPFA_PROPERTYUNIT | Used to map the WACS Property Unit value to ERPFA Asset Category and Asset Category segments. Asset Category segments (1-7) are used for fixed asset and asset category column is used for project asset. |
OUTL-BRT-WACS_ERPFA_EMAIL_ID | Used to configure email IDs to receive notifications. It maps the ‘from’ and ‘to’ recipient values to the mentioned email IDs. You can configure multiple emails by putting a comma to separate the email IDs. |
OUTL-BRT-WACS_ERPFA_ TAXJURISDICTION | Used to map WACS Tax Jurisdiction with the ERPFA Location and Asset Location segments. Note: make sure no empty value records are added in the WACS_TaxJurisdiction column. |
OUTL-BRT-.WACS_ERPFA_EXPACCOUNT | Used to map ERP Chart of account ID to Depreciation Expense account segment field names. |
