Property Name | Sample Value | Description |
asset.add.batchname | Oracle WACS | Fixed Value, concatenation of “Oracle WACS - “ and date in format DD-MON-YYYY HH24MISS. |
pa.add.processingmode | Create | Project asset addition processing mode. Fixed Value “Create” |
pa.add.assetype | ESTIMATED | Asset type for addition of project asset in Oracle Assets. Fixed Value “ESTIMATED” |
pa.add.depreciate | Y | Fixed Value "Y" |
retire.asset.trasaction type | COST RETIRE | Transaction type for Fixed asset retirement in Oracle Assets. Fixed Value “COST RETIRE” |
retire.asset.postingstatus | POST | Status to be updated while posting Fixed Asset retirements. Fixed Value “POST” |
retire.asset.transactionname | Retirement from Oracle Utilities WACS | Transaction name for Fixed Asset Retirement in Oracle Assets. |
email.flag | true | If this value is set to true, email notifications will be sent out. Valid values are true and false. |
extract.ftp.input.directory | /scratch/tmp | WACS directory where the Asset extract files are stored and for OIC to pick up from. Required to populate this when WACS is on-premises. |
extract.filename.prefix | ERPFA | Asset Extract file name prefix. It should have the same value as the batch parameter filename in Batch Process W1-ERPFA |
os.namespace | <your_os_ namespace> | WACS Object Storage namespace serves as a container for all your buckets and objects. Defines the namespace where the buckets and objects the Asset extract file resides. It is used while calling the Object Storage APIs. Required to populate this when WACS is in the cloud. |
os.bucketname | WACS-ERP_Assets_Cloud_Extract | WACS Assets Bucket name where the objects or files are stored. Define the bucket name where the Asset Extract files are stored. It is used while calling the Object Storage APIs. Required to populate this when WACS is in the cloud. |
extract.prefixtag.fileuploaded | Sent- | The text to append to the filename to mark the file as processed or uploaded in WACS-ERPFA. Shared property for the extract flows in this integration. |
notification.type | email | Notification type |
projects.implemented | Yes | Flag to indicate if the project implementation is in place or not. Default value 'Yes' |
fa.add.assettype | CAPITALIZED | Fixed asset addition asset type. It is a fixed value. |
fa.add.poststatus | NEW | Fixed asset addition initial posting status. It is a fixed value. |
fa.add.feedersystem | Utilities Work and Asset Cloud Service | Fixed asset addition feeder system |
fa.add.depreciate | YES | Fixed asset addition, depreciation value. Fixed Value “YES”. |
fa.add.queuename | NEW | Fixed asset addition queue name |
fa.add.transactionname | Oracle WACS Asset Integration | Fixed asset addition transaction name |
fa.adjst.transactionname | Adjustment from Oracle Utilities WACS | Fixed asset adjustment transaction name |
fa.adjst.transactiontype | ADJUSTMENT | Fixed asset cost adjustment transaction type. It is a fixed value. |
fa.adjst.poststatus | POST | Fixed asset adjustment posting status. It is a fixed value. |
fa.adjst.transfers.transactiontype | UNIT ADJUSTMENT | Fixed asset unit adjustment transaction type. It is a fixed value. |
assetNum.prefix | WACS | Prefix to add for each asset number |
pa.taxJuridiction | USA-CALIFORNIA-LOS ANGELES-OFFICE | Project asset location value. |
extract.ftp.output.directory | /scratch/tmp | WACS directory where the Asset extract files are stored and for OIC to pick up from. Required to populate this when WACS is on-premises. |
extract.prefixtag.filenotuploaded | Error- | The text to append to the filename to mark the file as error or not uploaded in WACS-ERPFA. |
