Overview
Oracle Utilities Work and Asset Cloud Service (WACS) helps users to track asset addition, installation, maintenance, and removal. This integration allows the passing of newly created or installed assets as project capital assets to the Oracle Project Costing module of Oracle Fusion Cloud ERP to determine the true cost of the asset.
Additionally, the integration supports the passing of capital spare assets to the Fixed Asset module, and also supports assets adjustments and retirements. This can be useful in tracking the status and value of fixed assets over time, which is important for financial and operational purposes.
For more information about the functionality, refer to the Oracle Utilities Work and Asset Cloud Service Integration to Oracle Assets documentation at:
The following diagram illustrate the high-level features of this integration:Illustrates the business processes supported in this product integration from Oracle Fusion Procurement Cloud to Oracle Utilities Work and Asset Cloud Service.
This integration supports the following flows:
Oracle Utilities Work and Asset Cloud Service Assets Integration to Oracle Assets
Oracle Utilities Work and Asset Cloud Service will generate an Assets extract file that includes asset additions, adjustments, and retirements records. The set of Oracle Integration Cloud integrations will process the file and integrate the data with Oracle Assets.
Following are the child flows:
• Asset Additions from Oracle Utilities Work and Asset Cloud Service to Oracle Assets
• Project Asset Additions to Project Capital Assets
• Non-Project Asset Additions to Fixed Assets
• Asset Adjustments from Oracle Utilities Work and Asset Cloud Service to Oracle Assets
• Project Asset Adjustments to Project Capital Assets
• Non-Project Asset Adjustments to Fixed Assets
• Asset Retirements from Oracle Utilities Work and Asset Cloud Service to Fixed Assets
