Software Requirements
The following table lists the supported applications and the respective versions:
Source Application
Version
Oracle Utilities Work and Asset Cloud Service
23A or higher
Oracle Utilities Work and Asset Management
V2.4.0.1.1 or higher
Oracle Integration Cloud
V23.1.3 or higher
Oracle Assets (Oracle Fusion Cloud)
23A or higher
This site works best with JavaScript enabled
