Oracle Integration Cloud GEN 3
In Oracle Integration Cloud GEN3, customizations can be added to the accelerator flows by using Extendable group. Extendable group supports STITCH for each functionality and these functionalities will be released by Oracle Integration Cloud.
To add customizations in GEN 3:
1. Add the Extendable group before invoking the mapping.
2. For complex or simple mapping use the STITCH function inside the extendable group.
3. Map the source element to the target element.
4. Click Save.
5. Activate the Integration.
In GEN3, existing customizations will not be overridden when the Oracle Integration Cloud package is being upgraded. The existing customizations will automatically merge to the higher version flows.
