Integration Overview
Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service helps to manage a fieldwork originated in Oracle Utilities Work and Asset Cloud Service using Oracle Field Service. The integration can be leveraged to create/update/cancel/complete activities in the field using the Oracle Field Service solution.
The major business flows revolve around activities and usage reporting. The activities are created in Oracle Utilities Work and Asset Cloud Service and sent to Oracle Field Service so that the mobile worker performs the activity. The field activity completion information is sent from Oracle Field Service to Oracle Utilities Work and Asset Cloud Service. In addition, the integration supports admin sync from Oracle Utilities Work and Asset Cloud Service to Oracle Field Service.
The following diagram illustrates the business processes supported in this integration.
![Illustrates the business processes supported in this integration product. Illustrates the business processes supported in this integration product.](../WACS-OFS_RELEASE_NOTES_23A/images/Overview_of_the_Integration.jpg)
In this integration Oracle Integration Cloud is used as a middleware to connect the applications.
