Timesheet/ Other Direct Charges Flag
This flag indicates whether a mobile worker is allowed to add a timesheet or other direct charges for an activity that has been completed.
In the Oracle Utilities Work and Asset Management master configuration, the following properties accept the Yes or No values.
• Allow Timesheet against completed activity.
• Allow ODC against completed activity.
To set the value of these properties in Oracle Field Service:
1. Navigate to
Configuration >
Resources,
Activities,
Inventories >
Properties. Search for Resource Usage Flag.
2. Click
Modify. Go to the
Enumeration values section. TS and ODC indicate Timesheet and Other Direct Charges respectively. Default value for both flags is "NO".
3. To change the value of flags, select or unselect the Active checkbox to make the corresponding enum values of YES/NO active or inactive respectively.
4. Click Change > Update to reflect the changes. Else, click Cancel.
