The following table shows the supported application versions in this integration:
Application
Version
Oracle Utilities Digital Asset Cloud Service
23B or higher
Oracle Utilities Grid Edge Distributed Energy Resources Management System
V2.6.0.1.0 or higher
Oracle Integration Cloud
V23.3.2.0.0 or higher
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
