OU OFSC DACS Activity Complete
The OFSC DACS Activity Complete flow is the main flow from Oracle Field Service to Oracle Utilities Digital Asset Cloud Service. It sends the activity completion information from Oracle Field Service to Oracle Utilities Digital Asset Cloud Service.
After adding the customization in Oracle Field Service, to send the customized elements back to Oracle Utilities Digital Asset Cloud Service, customized mappings should be added to the OIC Completion flow.
To add customizations in the OIC Completion flow:
1. Clone the Integration and enter the following details:
• Name: OU OFSC DACS Activity Complete
• Identifier: OUTL-OFSC_DACS_ACTIVITY_COMP_CM
2. Navigate to the map activity where the custom mappings should be added.
3. Click Edit and select the Code tab. The XSLT snippets are displayed.
4. Add the customized mappings in the corresponding parent schema element.
Follow these steps to add customizations to the other integration flows.
