About Oracle Integration Cloud
Oracle Integration Cloud, also referred to as Oracle Integration Cloud Service, is a platform offered by Oracle Corporation. It is designed to simplify and streamline the process of connecting various applications, systems and services within an organization as well as with external partners and cloud based services regardless they are on-premise or in the cloud.
Oracle Integration Cloud is a unified platform to integrate the applications, automate processes, and create applications.
Using Process Builder, the business processes can be rapidly designed, automated, and managed in the cloud. Using integrations connect the applications into a continuous business flow. The applications that are on cloud and on-premises can be integrated using Oracle Integration Cloud. The lookups help to match application specific codes between the two applications.
Integration Insights and Stream Analytics helps to simplify and extract business metrics and create custom dashboards.
