Supported Applications
The following table lists the supported applications and their versions in this integration:
Supported Source Application
Version
Oracle Utilities Work and Asset Cloud Service
20C or higher
Oracle Utilities Work and Asset Management
20C or higher
Oracle Integration Cloud
20.4.2.0.0 or higher
Oracle ERP Financial Cloud
20C or higher
This site works best with JavaScript enabled
