DVM Name | Description |
OUTL-BRT-WACS_ERPPM_ConfigProps | Used to configure the integration properties. Maps PropertyName column to the respective Value column. Note: Do not change the values under the PropertyName column. |
OUTL-BRT-ERPPM_WACS_ProjectStatus | Used to map the ERPPM_ProjectStatus value to WACS_ProjectStatus. |
OUTL-BRT-ERPPM_WACS_ProjectCategory | Used to map ERPPM_WorkType with WACS_ProjectCategory. |
OUTL-BRT-WACS_ERPPM_OwningAcc essGroup | Used to map WACS_OwningAccessGroup with ERP_OrganizationName. |
OUTL-BRT- WACS_ERPPM_Email_ID | Used to configure email IDs to receive notifications. It maps the 'from' and 'to' recipient values to the mentioned email IDs. You can configure multiple emails by using a comma to separate the email IDs. |
