Property Name | Sample Value | Description |
task.create.chargeable flag | true | Constant value “true” for ERP task creation |
task.create.elementtype | FINANCIAL | “FINANCIAL” |
task.create.progresss. status.code | IN_PROGRESS | Constant value for create task |
task.source.app | WACS | Value of external application configured in ERP |
task.update.chargeable flag | false | Constant value “false” When WACS activity is closed/canceled |
task.update.progresss. status.code | COMPLETED | Constant value for task completed/close/cancelled |
task.completion. percentage | 100 | Constant value “100”. When WACS activity is completed. |
task.update.capitalizableflag | false | Constant value “false”. When WACS activity is cancelled. |
project.allowcharge | W1YS | When this indicator is set to “yes” other records can charge against the project. |
project.burden.or.raw | cost | burden or cost This flag will be defined by users based on ERP implementation. |
notification.error.flag | true | If this value is set to “true”, notifications will be sent out in case of any errors. Valid values are true and false. |
notification.type.email | true | If this value is set to true, email notifications will be sent out. Valid values are true and false. |
task.finishdate.duration | 7 | If WACS does not send any task finish date upon activity approval and ERP project doesn't have any end date, then task finish date would be task start date + this field. |
