Scheduling the Batch Process
Schedule the W1-ERPFA batch job to generate asset extract file. It has a couple of parameters that can be used to control which synchronization request should business objects process.
W1-ERPFA: This batch process is responsible for generating the asset extract file for ERP fixed/project assets when an asset is created/updated/removed in Oracle Utilities Work and Asset Cloud Service.
The batch job should be scheduled to run with the following job parameters:
• Batch code: W1-ERPFA
• fileIntegrationType: W1-ERPFAExtract
• fileName: ERPFA_{BC}{BN}{TN}.csv
• filePath: tmp/ (this is the relative path)
• fileFormat: CSV
