Adding Compatible Units
A compatible unit identifies the resources necessary to install/remove assets as they relate to construction work.
To add a compatible unit:
1. After creating the construction work activity, navigate to the Construction Locations tab.
2. Click Add Location and then add the Work Location.
3. Against the location, click Add CU.
4. Provide the CU ID, Quantity, Responsible Party, and Cost Center.
5. Approve the construction work order. Make sure the status is active.
6. Click Finish.
