Testing the Integration Flows
The following table lists the end point URLs for respective applications in which these endpoints need to be configured. Configure the same and perform an end-to-end testing.
Integration Name
End Point URL to be Configured
Application to be Configured
Oracle Utilities WACS OFSC Activity Process
https://OIC_Host:OIC_Port/ic/ws/integration/v1/flows/oracleutilities/OUTL-BA-WACS_OFSC_ACTIVITY_PROC/1.0/
WAM/WACS
Oracle Utilities OFSC WACS Activity Complete
https://OIC_Host:OIC_Port/ic/api/integration/v1/flows/ofsccloudadapter/OUTL-BA-OFSC_WACS_ACTIVITY_COMP /1.0/notify
As OFSC is event based, there is no need to configure the integration endpoint URLs. Subscription for the event will be created once the respective integration is activated.
Oracle Utilities WACS OFSC Admin Data Sync
https://OIC_Host:OIC_Port/ic/api/integration/v1/integrations/OUTL-BA-WACS_OFSC_ADMIN_SYNC%7C01.00.0000 /schedule/jobs
An OIC initiated flow that can be triggered by selecting the hamburger and select Submit Now.
Oracle Utilities OFSC WACS Resource Usage Details
https://OIC_Host:OIC_Port/ic/api/integration/v1/flows/rest/OUTL-BA-OFSC_WACS_RES_USAGE_SEND /1.0/resourceUsage
OFSC
Oracle Utilities OFSC WACS Asset Query
https://OIC_HostOIC_Port/ic/api/integration/v1/flows/rest/ OUTL-BA-OFSC_WACS_ASSET_QUERY /1.0/assetQuery
https://OIC_Host:OIC_Port/ic/api/integration/v1/flows/rest/OUTL-BA-OFSC_WACS_ASSET_QUERY/1.0/assetQueryDetailsPickup
OFSC
Oracle Utilities OFSC WACS Activity Interim Status
https://OIC_HostOIC_Port/ic/api/integration/ v1/flows/ofsccloudadapter/ OUTL-BA-OFSC_WACS_ACTIVITY_STAT /1.0/ notify
OFSC
Oracle Utilities OFSC WACS Work Request
https://OIC_Host:OIC_Port/ic/api/integration/v1/flows/ofsccloudadapter/OUTL-BA-OFSC_WACS_WORK_REQ/1.0/notify
OFSC
Oracle Utilities OFSC WACS Work Order
https://OIC_Host:OIC_Port/ic/api/integration/v1/flows/ofsccloudadapter/OUTL-BA-OFSC_WACS_WORK_ORDER/1.0/notify
OFSC
Oracle Utilities OFSC WACS Activity Pull Update
https://OIC_Host:OIC_Port/ic/api/integration/ v1/flows/rest/OUTL-BA- OFSC_WACS_ACT_UPDT_PULL_/1.0/ retrieveUpdates
OFSC
Oracle Utilities OFSC WACS Route Activation
https://OIC_Host:OIC_Port/ic/api/integration/ v1/ integrations/OUTL-BA- OFSC_WACS_RTE_ACTIVATION/1.0/notify
OFSC
Oracle Utilities WACS OFSC Schedule Storeroom Sync
https://OIC_Host:OIC_Port/ic/api/integration/ v1/ integrations/OUTL-BA- WACS_OFSC_SCH_STRM_SYNC%7C01.22.3000/schedule/jobs
OFSC
Oracle Utilities WACS OFSC Storeroom Admin Sync
https://OIC_Host:OIC_Port/ic/api/integration/ v1/flows/ofsccloudadapter/OUTL-BA-WACS_OFSC_STRM_ADMN_SYNC%7C01.22.3000/schedule/jobs
WACS
Oracle Utilities OFSC WACS Storeroom Sync
https://OIC_Host:OIC_Port/ /ic/api/integration/v1/flows/rest/OUTL-BA-OFSC_WACS_STOREROOM_SYNC/1.0/syncStoreroom
OFSC
