Migrating from OIC Test Environment to Production
Make sure all Oracle Integration Cloud artifacts are imported successfully.
To import the customizations added in the test environment to production:
1. Export the wacs_ofsc_fieldwork_custom_23B package from the test environment and import it into the production environment.
2. Configure all your connections.
3. Activate the base integrations and customized integrations, and configure the respective end point URL into the Oracle Utilities Work and Asset Cloud Service Message Sender.
4. Deactivate the base integrations for which a cloned, customized integration copies were created.
