Known Issues
The known issues at the time of this integration release are:
• Even after the supervisor locks an activity, assistant mobile worker is able to perform the asset level operations.
• Undo use item is getting displayed in day2 when the item is used for day1 in multiday activity.
• Error message is not displayed in the Oracle Field Service mobile screen when the crew member starts the successor activity before the predecessor activity.
• In the Oracle Field Service mobile screen, when the crew navigates to the Activity Dependencies tab, the same activity is displayed on the Successor and Predecessor tab.
• When the user refreshes an activity in Oracle Field Service after the asset is issued from Oracle Utilities Work and Asset Cloud Service, even though there is no asset installed, when the user uses the item from truck, the All Applicable Assets button is displayed on the Planned Service History plugin.
• When the user attaches an issued component to any asset, the All Applicable Asset button is not displayed in the Planned Service History plugin.
• Admin Sync known issue:
• The enumeration “wam_actType_psh” to maintain the relationship between the activity types and PSH associated with the activity types. It stores the PSH details as part of the name for the enumeration label. In Oracle Field Service, there is a restriction on the size of the name. If there are more than 5-6 PSHs for that activity type, Oracle Field Service displays a 500 error.
• User cannot click the Calendar in IOS (all date-time and date fields).
• When there are pending service histories at asset or activity level, mobile worker cannot see the error in French.
• When admin assigns the multiday activity to a mobile worker, the segment duration is not displayed on the Activity Details page and timesheet in the Resource Usage plugin.
