Asset Installs and Removals
This section includes instructions to perform asset installs and removals.
Installing Assets
To install an asset:
1.	Start the activity.
2.	To install an asset, click the location.
 3.	Click
Install Asset.
 4.	Enter the
Badge Number of the asset to be installed in this location and click
Install.
 5.	The newly installed asset is shown in the
Installed pool.
 To attach a component:
2.	To attach a component, click the asset.
 3.	Click
Attach Component.
 4.	Enter the
Badge Number of the component to be attached and click
Attach.
 	The attached component is shown in the
Installed Pool.
 To move an asset out of service:
2.	To move an asset
out of service, click the asset.
 3.	Click
Out of Service.
 4.	Enter the
effective date/time and click
Submit.
 	The asset moves to ‘out of service’ status in
Deinstalled pool.
To remove an asset/component:
2.	Click the asset/component to be removed.
 3.	 Click
Remove.
 4.	 Enter the
submit.
 	The asset/component is removed and moved to the
Deinstalled pool.
 To undo the installation:
1.	To undo an installation, click the newly installed asset in the
Installed pool.
 2.	Click
Undo Install Asset.
 3.	Click
Submit.
 	The asset/component installation is undone and it disappears from the installed pool.
To undo a newly attached component:
1.	To undo attach, click the newly attached component in the installed pool.
 2.	Click
Undo Attach Component.
 3.	Click
Submit.
 4.	The attach operation is undone and the component disappears from the installed pool.
To navigate to the parent asset:
1.	To navigate to the parent asset, click the newly attached component in the i
nstalled pool.
 2.	Click
Go to Parent Asset to navigate to the parent asset to which the component is attached.
 To undo an asset removal:
1.	To undo remove, click the removed asset.
 2.	 Click
Undo Remove.
 3.	 Click
Submit.
 	The removal is undone and asset disappears from the deinstalled pool.
To move an asset back to service:
1.	To move asset back to service, click
Asset in
Out of Service.
 2.	Click
Back to Service.
 3.	 Click
Submit.
 	The asset moves to the Existing pool.
To replace an asset:
1.	Click the asset that needs to be replaced.
 2.	Click
Replace.
 3.	Enter the badge number of the asset to be replaced with and click
Replace.
 	The new asset moves to the
Installed pool and the replaced asset moves to the
Deinstalled pool.
To replace the component:
1.	Click the component to be replaced.
 2.	 Click
Replace.
 3.	 Enter the badge number of the replacing component and click
Replace.
 	The replaced component moves to the deinstalled pool and the newly attached component moves to the installed pool.
To undo replace an asset:
1.	Click
Installed Asset/Component.
 2.	Click
Undo Replace.
 3.	Click
Submit.
 	The replaced asset moves back to existing pool.
 4.	Repeat the above steps to undo replace for a component.
