Service Configurations
Service Configuration properties are specific to SOA composites. These are used to make changes in specific composite behavior.
Service Name
Property Name
Default / Shipped Value
or System ID of Initiating System
Description
OUCCBOUNMSCustomerDataSyncReq
EBF
BusinessError.NotificationFlag
true
If set to true, the business error notification is sent via email.
TechnicalError.NotificationFlag
true
If set to true, the technical error notification is sent via email.
OUC2MOUNMSCustomerSyncJMSRead
Svc
OUC2M.F1-UpdateAndTransitionSyncRequest.Endpoint.URL
https://C2M_HOST:PORT/C2M_ContextRoot/F1-UpdateAndTransitionSyncRequest
The C2M Endpoint URL for F1 Update and Transition Sync.
OUC2MOUNMSTroubleCallInterfaceEBF
Default.SystemID
OU_C2M_01
Initiating system ID
Extension.PreXformC2MtoNMS
False
If set to true, the pre transformation extension service is invoked.
Extension.PostXformC2MtoNMS
False
If set to true, the post transformation extension service is invoked.
NMS.C2MCallSourceID
2
Define unique call source ID for C2M.
• This C2M call source ID indicates that the trouble call was created in C2M.
• This will also ensure that the external ID in the trouble calls table will have a unique value. NMS will prefix the call source ID to the external ID coming from C2M.
C2M.LocationType.StreetIntersection
C1IS
C2M uses the location type to determine whether a street intersection or street segment was populated for the location of a fuzzy call.
This is the C2M Location Type value for Street Segment.
Location Type coming from C2M is not mapped to NMS.
It is only used by the integration for the mapping of the cross street or block number.
C2M.LocationType.StreetSegment
C1SS
This is the C2M Location Type value for Street Intersection.
false
false
OUC2MOUNMSJobHistoryQuery
Default.SystemID
OU_C2M_01
Initiating system ID.
false
false
Extension.PreXformNMStoC2M
false
Extension.PostXformNMStoC2M
false
NMS.NumberOfDaysOfHistory
60
Define the Number of Days Of Job History to return.
true
true
OUC2MOUNMSTroubleCallsQueryEBF
Default.SystemID
OU_C2M_01
false
false
false
false
60
Define the Number of Days Of Call History to return
true
true
OUC2MOUNMSPlannedOutagesQuery
EBF
Default.SystemID
OU_C2M_01
false
false
false
false
10
Define the Number of Days Of Planned Outages to return.
true
true
