Property (XPath Representation) | Description | Example |
SOA Information | ||
<config> | ||
<config><modulename> | Name of the integration module. | Default: C2M-NMS Do not change this value. |
C2M Application Information | ||
<C2M-NMS><C2M><protocol> | The protocol on which the application is accessible. | http or https |
<C2M-NMS><C2M><host> | The host name of Oracle Utilities Customer To Meter server application. | C2M_HOST.yourdomain.com |
<C2M-NMS><C2M><port> | The port number of Oracle Utilities Customer To Meter application. | C2M_PORT_NO Example: 1961 |
<C2M-NMS><C2M><contextRoot> | The context root of the application. | C2M_CONTEXT_ROOT _NAME ouaf/XAIApp/xaiserver (for XAI services) ouaf/webservices (for IWS services) |
<C2M-NMS><C2MB><policy> | The security policy that C2M accepts when invoking it’s web service. | Use oracle/ wss_http_token_client_policy for XAI services or refer to the Security Policies section for more information when invoking IWS services. |
<C2M-NMS><C2M><ApplicationUsername> | The login user name of the application. | C2MUSER |
<C2M-NMS><C2M><ApplicationPassword> | The login password of the application. | C2MPWD |
NMS Application Information | ||
<C2M-NMS><NMS><ApplicationUsername> | The login user name of the application. | NMSUSER |
<C2M-NMS><NMS><ApplicationPassword> | The login password of the application. | NMSPWD |
<policy> | The security policy that NMS accepts when invoking it’s web service. | Use oracle/ wss_http_token_client_policy for XAI services or refer to the Security Policies section for more information when invoking IWS services. |
SOA Admin Server | ||
<SOA><AdminServer><hostname> | Host name of the server where admin server hosting SOA suite is installed. | adminserver.example .oracle.com |
<SOA><AdminServer><portnumber> | Port number the admin server (hosting SOA suite) is listening to. | 7001 |
<SOA><AdminServer><servername> | Admin server name (hosting SOA suite) | Admin Server |
<SOA><AdminServer><username> | User name used to log in as an Admin server (hosting SOA suite) administrator. | weblogic |
<SOA><AdminServer><password> | Password used to log in as an Admin server (hosting SOA suite) administrator. | xxxxxx |
<SOA><AdminServer><domainname> | WebLogic domain name hosting SOA suite. | soa_domain |
SOA Managed Server | ||
<SOA><ManagedServer><hostname> | Host name of the server where managed server (hosting SOA suite) is installed. | managedserver.example.oracle.com |
<SOA><ManagedServer><portnumber> | Port number the managed server (hosting SOA suite) is listening to. | 8001 |
<SOA><ManagedServer><servername> | Managed server name (hosting SOA suite) | Managedserver1 |
<SOA><ManagedServer><username> | User name used to log in to managed server (hosting SOA suite) as an administrator. | weblogic |
<SOA><ManagedServer><password> | Password used to log in to managed server (hosting SOA suite) as an administrator. | xxxx |
Oracle HTTP Server Information | In a non-cluster environment these properties would be same as <ManagedServer> values | |
<SOA><OHS><hostname> | The host name of the Oracle HTTP Server. | Oracle http server where cluster is managed |
<SOA><OHS><portnumber> | The port number of the Oracle HTTP Server. | Example: 7777 |
<SOA><OHS><servernames> | The list of server names that are defined as Managed Servers/Clusters. | In multiple managed servers, provide comma separated values. Example: soa_server1, soa_server2 |
<SOA><OHS><Protocol> | The protocol on which the application is accessible. | http |
MDS DB Information | ||
<SOA><mdsconfig><mdsdbusername> | User name used to log in to MDS schema. | XXX_MDS |
<SOA><mdsconfig><mdsdbuserpassword> | Password used to log in to MDS schema. | **** |
<SOA><mdsconfig><mdsdbhostname> | Host name of the server hosting the database containing MDS schema. | Db.hostname.oracle.com |
<SOA><mdsconfig><mdsdbportnumber> | Port number of the database containing MDS schema. | 1521 |
<SOA><mdsconfig><mdsdbsid> | SID of the database containing MDS schema. | SID |
JMS Information | ||
<SOA><JMS><serverName> | The JMS server name | Default: C2MNMSFJS Do not change. |
<SOA><JMS><ModuleName> | The JMS module name | Default: C2MNMSFJM |
<SOA><JMS><SubDeploymentName> | The Subdeployment name | Default: C2MNMSFileSubDeployment Do not change. |
<SOA><JMS><SubDeploymentName> <JMSServerTarget> | The SOA Managed Server Target for JMS server. | soa_server1 For cluster environment, give only one managed server name under the cluster |
<SOA><JMS><SubDeploymentName> <JMSModuleTargets> | The JMS Module targeted SOA managed servers/Clusters. | soa_cluster For cluster environment give comma separated managed server names under the cluster or multiple cluster names |
<SOA><JMS><PersitentStoreName> | The file store persistence details. | Default: C2MNMSFileStore |
<SOA><JMS><PersitentStoreType> | JMS persistent store type (FileStores or DBStore). Deployment script supports a file | Default: FileStores |
<SOA><JMS><PersistentStoreFilename> | Directory path name where the file based persistent store should be created. | /opt/SOA12c/Product_Homes/C2M-NMS |
<SOA><JMS><JMSCFName> | The file name of the ConnectionFactory. | C2MNMSCF |
<SOA><JMS><JMSCFJNDI> | The JNDI file name of the ConnectionFactory. | jms/C2M-NMS/C2MNMSCF |
