Updating the AIAConfiguration Properties File
To update the AIAConfiguration properties file:
1. Navigate to the AIAMetaData/config folder and open the AIAConfiguration properties file (OUC2MOUNMSConfigurationProperties.xml).
2. Modify the value of NMS.MultipleInstance to “true” to support multiple Oracle Utilities Network Management System instances.
Example: <Property name="NMS.MultipleInstance">true</Property>
3. Restart the SOA servers.
