Importing the Oracle Integration Cloud Package from Oracle Cloud Marketplace
All integration points are shipped as part of single package (.par) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Oracle Utilities Customer Cloud Service”.
4. Browse through the list of applications and select the pre-built integration package to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. My Oracle Support portal opens.
8. Download the integration package from My Oracle Support.
9. When prompted, select the server where the pre-built integration file should be uploaded.
The pre-built integration is imported as a package file that is visible on the Packages page in Oracle Integration Cloud.
10. On the Integrations page, the individual integrations of the imported package file that are designated with a BUILT BY ORACLE message are displayed.
Important! This note is applicable only for existing customers. Make sure to take a backup of the existing package and lookups and perform the cleanup before proceeding with the new package import. The cleanup includes deactivating the existing flows in this package and deleting the package, connections, lookups and libraries used in the integration.
To import a package in Oracle Integration Cloud:
1. Login to Oracle Integration Cloud.
2. Navigate to Integrations > Designer > Packages.
3. Click Import.
4. Select the .par file downloaded from Oracle Cloud Marketplace.
5. Verify if the package is imported is successfully.
